configure isis timer csnp-interval
configure isis [vlan all | {vlan} vlan_name] timer csnp-interval seconds {level [1 | 2]}
Description
This command sets the minimum time between consecutive CSNP transmissions on the specified interface.
Syntax Description
vlan all Applies the timer configuration to all IS-IS VLANs.
vlan_name Specifies a single VLAN to which the timer configuration applies.
seconds Sets the timer interval. The range is 1 to 65535 seconds.
level [1 | 2] Limits the configuration to either level 1 or level 2. If neither level 1 nor level 2 is specified, the configuration applies to both levels.
Default
10 seconds.
Usage Guidelines
Periodic CSNPs are only sent on broadcast interfaces and only by the DIS.
The following command sets the CSNP interval time for all IS-IS VLANs to 15 seconds:
configure isis vlan all timer csnp-interval 15
Platform Availability
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
